Introduction
Sometimes there is a need to reduce the amount of elements in an data array for mid and post processing reasons. This is a simple example on how this can be done.
Steps to Complete
Download the attached VI so that you can view in detail how the data array is reduced. In the block diagram, an array of random numbers is built and then passed to another for loop that will create a new array that will contain the reduced data set.
In the front panel you will see the array of random numbers (Input Array), an array of Booleans that show if an element has been removed or not (Boolean Element Array which is in negative logic), and the final Output Array.
Additional Notes
LabVIEW Help Grouping Data with Arrays and Clusters
