Overview
A number of VIs for generating a HTML report.
Description
These VIs can be used to generate a HTML file, an example file is contained within the archive. Styles for different sections can easily be modified within the header section of the HTML. Also included is a VI to automatically open the file after it is created.
Charts can be added and are stored as PNG files, automatically stored in the same directory as the HTM and with a similar file name. A function to add a 2D table is also included, tables appear with a simple 1 pixel border.
