This is a set of code that automatically resizes the columns in a Table, Multicolumn Listbox, or Tree automatically based on the control size, and settings defined.
Included is the Demo Column Resize VI which has instructions on the front panel. It allows for setting the column widths based on a constant pixel size, or a percentage of the remaining control size minus the constants. The intent is to create a control that takes up the entire width of the space in the control, but can expand certain columns based on if a control, or the pane it is fit to, increases or decreases in size.
LabVIEW 2015 or newer
OpenG Array package
Unzip code, run the Demo. The demo shows how the resize works on the three different control types and keeps track of the settings for each unique control reference.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
