Ever wondered how long your code really is? Ever wanted to know, how many wires have you actually laid? Would all the wires from your project allow you to finally escape your office through the window if you'd tie them together?
Here's a tool that let you answer all those questions, asked by generations of LabVIEW programmers!
Enjoy!
Instructions: unzip attached archive. Inside you'll find two versions of the project:
Pick your version and run _Main.vi, then follow the instructions. Enjoy! ![]()
PiDi, this is fantastic! I ran it on your WireLength project itself, which comes to...2.68 meters of wires!
I guess I'll have to start using lots of local variables and overlapping block diagram items to keep my wire score down. ![]()
Can you save for previous version? I have LabVIEW 2009, thanks.
LV2009:Inside CalculateVIWiresLength.vi cannt found "Traverse for GObjects.vi" ![]()
1m=100cm, not 1000cm.![]()
Cool! I have 36.72m of wire!!!!
Cool. My newest project has 26m of wires...
And maybe I overdid it a bit when I put your program on a quite big project. It's now running for 20minutes just loading (not calculating) and consumes more than 1.3GB of memory.
Now I'm really wondering if it will crash or spit out an awesome result ![]()
