Community Documents
help for file browse programatically
hi,
i m writing a ANN backpropagation using labview and matlab.
i want to input or select file for testing the network in run time, so i use the file path inside while loop.
but when i click on the files subseuently, these change on front panel,but the block diagram shows no change, and so i get same data repeatedly.
any help please
Contributors
