Components
CVT Client Communication (CCC)
Hi Eric,
The CCC Client Init VI should create the groups itself, so you shouldn't need to manually create them.  I suspect there is some code path that is skipping the group initialization in this case.  I will look into what might be happening, and I'll let you know what I find.
Chris
Message 21 of 98
(15,226 Views)
Cmal,
Ok, I looked into my CCC init case and I don't see anywhere that those tags are written too, at least not using standard CVT vis. I would guess its supposed to happen in the client config read and write VIs inside of the client init. I dont see any "CVT" type VIs or code in here so im not sure how it would create that group and update the CVT table...
Is it possible that CCC just hasn't been updated fully yet for the new CVT version?
Eric
Message 22 of 98
(15,221 Views)
@Etarkleson wrote:
Cmal,
Eric
The write group on the client side is first created inside "Client Init.vi >> Client Configure Write.vi >> Initialize Address_Index Lists.vi".  3.0.0.3 is the most current version of CCC, so it is up to date with the latest CVT updates.  You can enable debugging in this VI and check to make sure it is being called correctly.  If the Group Tags VI does not exist in the CCC VIs you have installed, could it be possible that you are using an older version of the library?
Chris
Message 23 of 98
(15,207 Views)
Hey Chris,
I found the piece of code you are referring too. I had actually gone in there and commented that section out when troubleshooting earlier problems... Oops!
Thanks for your help,
Eric
Message 24 of 98
(15,194 Views)
I programmed a VI and got the error message "Form Single Group - 53167" on my client.
So I searched for an example and found "CCC client and Server.lvproj". I let the serve VI
run on my desktop PC and because I don't have a cRio at the moment, the client VI on
my notebook. It performed well, anyway i didn't find the problem in my self written programm.
Then I modified the example VI as shown in the annexed pictures: I removed the variables
subseqeuntly from the tag list on the server and client side. For a better illustration I
adapted the controls and icons, but i didnt do any changes in the code. If there are only
two variables (Float1<->Input1, Float2<->Input2) left, I get the same error.
My version of LabView is 12.0f3, CVT 3.0.0.13 and CCC 3.0.0.3
Regards
George
Server
Client
Message 25 of 98
(15,119 Views)
Hi gkit,
Have you found any solution to your problem yet? I'm running into similar issues and trying to figure out the reason.
-Matti A.
Message 26 of 98
(15,073 Views)
Hello Matti,
Sorry, I have no advance in this. I am wondering because it seems that the other people
here are successfully using the CCC !?
I hope that any of them will read this thread and have an idea.
It's a promising feature, but at the moment I can't use it.
Regards
George
Message 27 of 98
(15,067 Views)
Ok, I think I have a clue of what is going on.
It seems you have to have at least one of both Write/Read type of tags to make it work without error. Otherwise it throws that "No Tags Found to Group" error (537167). Data type doesn't seem to matter.
-Matti A.
Message 28 of 98
(15,061 Views)
-Matti A.
Thanks for reporting this issue.  It is indeed a problem in the CCC library where it expects at least one read tag and one write tag to exist.  It has been fixed in the latest version of CCC, which should be available on the LabVIEW Tools Network shortly.
Chris M
Message 29 of 98
(15,047 Views)
Great, thank you!
Message 30 of 98
(15,042 Views)
