Components
Distributed Timebase (DTB)
Post your questions or comments on the Distributed Timebase (DTB) component here.
(10,822 Views)
Hi,  just downloaded and installed using all the defaults. When I went to open the two example VIs they could not find the DTB VIs.  I had to manually point them to the correct path. They leave out the \LabVIEW 8.2\ portion of the path.
Here's the warning:
C:\Program Files\National Instruments\LabVIEW 8.2\examples\DTB\IO_Node_example.vi
    - The VI expected to be at "C:\Program Files\National Instruments\user.lib\DTB\DTB Abort Timebase.vi" was loaded from "C:\Program Files\National Instruments\LabVIEW 8.2\user.lib\DTB\DTB Abort Timebase.vi".
By the way, the Components are very timely for our current realtime project. Smiley Happy  I was just talking last week with another senior guy about our need to code up a timing & sync library and then I found the DTB when I got home Friday night.  Keep up the good work!
Mike Ashe
(10,810 Views)
Thanks for the feedback.
There was a minor problem with the installer that has been fixed in the 1.0.5 distribution.
Doug
(10,804 Views)
We're using DTB to synchronise a couple of systems, PC and CompactRIO. I just noticed a problem on the PC.
When I build my VI into a .exe file DTB won't work. The program runs but I get a time back in 1904. Running the same VI from within LabView works fine.
Any idea what the problem is, is this a known problem or?
(9,936 Views)
What version of LV are you using?
(9,931 Views)
Labview 8.6  on Windows XP
(9,924 Views)
I found a solution to my problem, indicating
it probably is not a problem with DTB, but rather with Labview.
While debugging I found that if I set the source file settings for Timebase and Time reference in the build properties to NOT remove the front panel, then it works. But with the default settings
it dont - and no warning.
(9,906 Views)
