Components
Generic Configuration Editor (xCE) Reference Example
There is a new version of CEF on the tools network now with this change.  Version 2.1.1.105
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
Message 31 of 36
(7,378 Views)
Hi Benjamin
Great news. But unfortunately I cannot see the current Version in my VI Package Manager. What am I doing wrong?
Thanks in advance
Markus
Message 32 of 36
(7,373 Views)
Hi QSI,
     you have to click refresh in VIPM for it to refresh the REPO.
Best Regards
Benjamin C
Message 33 of 36
(7,363 Views)
Hi Benjamin
Thats what I did this morning, without success....
In the meantime I downloaded the package from this link:
http://download.ni.com/evaluation/labview/lvtn/vipm/packages/ni_lib_config_editor/
Thanks a lot for the new accessor. It works fine and is real added value...:-)
Best Regards
Markus
Message 34 of 36
(7,359 Views)
Hi
It seems there ist a "memory leak" in the following VI:
"C:\Program Files\National Instruments\LabVIEW 2015\vi.lib\NI\Configuration Framework\hierarchy repo\WriteTree.vi"
For test purposes I call this VI every 5s. As a result LabVIEW increases memory from around 230MBytes (LabVIEW 2015 SP1) to over 1GByte within a day. LabVIEW crashes later on on some point...
Calling the VI "Request Deallocation" in the caller -VI of "WriteTree.vi" does not help.
Just wanted you to know. It does not really matter for my application (at the moment;-), as in normal case the VI is called only a few times (< 100) within a week and the server, on which my application runs, is booted once a week.
Best regards
Markus
Message 35 of 36
(6,731 Views)
Thanks for the feedback.  xCE has been depriacate to the CEF.  CEF is the next generation and built on a lot of the xCE.  You may want to post this on there forums to see if it still an issue,
Brian K.
Message 36 of 36
(6,719 Views)
