Components
Multi-Process Engine (MPE) Reference Library
Sure thing.  I forgot to downgrade the examples to 8.5.  Here they are.
Brian K.
Message 11 of 14
(5,663 Views)
Is this Library Support LabVIEW 2010 Realtime?
I run the Example on Windows perfect.
But when I follow the Step in the guide Running the Example on a Real-Time Target, RT program runs incorrect,
It Seems that RT Server VI cann't find VI build in RTEXE.
Thanks for any help!
CLA & CLED
Message 12 of 14
(5,032 Views)
Not sure.  Haven't tried it in LV 2010.  What kind of error are you seeing?  Which file does it say it is missing.
Brian K.
Message 13 of 14
(5,025 Views)
it seems that when open RTEXE and list VI in it,an file not found error occoured.
May be I could use souce code distrubition instead the rtexe?
I will get some try on it.
CLA & CLED
Message 14 of 14
(5,015 Views)
