Comunidad NI México Discussions
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Temporizador
Hola buenas,
Me gustaría saber como puedo hacer para llevar un conteo del tiempo que ha sido pulsado un boolean. No se si Labview traerá un comando para ello o si hay algún otro modo.
Gracias
0 kudos
Mensaje 1 de 5
3.797 Vistas
I was going to point you to the Spanish Language Board, but I cannot find it!  There are, or were, a number of Boards for other languages, but they seem to have vanished from the NI Community Directory.  I'll ask a Moderator ...
Bob Schor
0 kudos
Mensaje 2 de 5
3.755 Vistas
Hi Bob Schor,
Thank you for answering.
I'll make my question in English so maybe you can help me. I'm trying to know how many time a boolean (or any bottom) is being press. I think it could be like a timer or counter that records the ammount of time a boolean has been pressed so I can exactly know the time with the commas.
I look forward your answer and thank you very much for your help,
Asier
0 kudos
Mensaje 3 de 5
3.744 Vistas
Hi Axif,
use an event structure to capture button press (aka value change) events of your buttons!
In the event case you can store the button label and a timestamp in a log or count the events for each button…
@Bob: Did you find the "Regional Communities" down at the end of the forum tree?
0 kudos
Mensaje 4 de 5
3.739 Vistas
Axif,
     I think GerdW gave an excellent answer (he generally does), and also pointed out the Regional Communities that I somehow managed to overlook earlier (I swear I searched that list -- maybe I have a Blind Spot or what my at-home Neurologist calls a scotoma -- to paraphrase the Verizon Guy, "Can you See it Now?").
Bob Schor
0 kudos
Mensaje 5 de 5
3.717 Vistas
