Continuous Integration
ClearCache addition to LabVIEW CLI
Something a bit surprising happened to me today with my GitLab CI :
I have 2 runners, a Linux one and a Windows one (yes, my code is supposed to compile on both OSes)
After a push on a feature branch, my runners were triggered, my steps are
- mass compile the project folder
- run unit test suite (I use Caraya)
- run module validation (DQMH)
- compile EXE
- Close LabVIEW
All the steps went fine on both runners. This feature branch is not yet ready to be merged in dev
The a bit latter, back on my dev branch, I push a few commits, my runners were triggered with the same steps
On the Linux runner, all went fine and the Windows runner failed during mass compile.
I went on the Windows runners opened the project to take a look at the broken VIs, it turns out that a typedef cluster was causing some broken VIs, what really surprised me is that it had the modifications made on the feature branch.
No, I'm not crazy, I didn't do anything stupid in git.
So I didn't do any modification on the runner,
I closed the project,
Cleared the compile object cache,
And closed LabVIEW,
Then I went on GitLab and manually triggered the runner again on the dev branch : all the steps completed successfully.
So I created a "ClearCache" addon for the LabVIEW CLI and included it before the mass compile in my CI steps.
Has anyone ever seen this?
I'm blaming LabVIEW for this, am I wrong?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,396 Views)
I don't know who is to blame, but I have definitely encountered this and I have written a similar G-CLI step to clear the cache and call it very liberally.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(3,385 Views)
Our Release Automation Tools programmatically clear all caches at the start of every pipeline, and again clear the appbuilder cache before each build job.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(3,357 Views)
Thank you both for your feedbacks, so I'm not alone.
Nice acronym 😅
Epictetus
Antoine Chalons
(3,350 Views)
