Continuous Integration
Run multiple LabVIEW CLI command in the same time
@James_McN  a écrit :
Thats a great idea for a workaround.
To be fair this is Fab’s idea 😇
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 11 of 14
(3,613 Views)
I ran into similar problem too. And my solution is to set my node's "# of executors" property to 1. So jobs will execute one by one.
Message 12 of 14
(3,515 Views)
I am digging in to the same issue now, it seems that error comes from logging LV class in labviewCLI:
Located in:
C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI\Operations\Utilities\Logger
I am trying to run multiple builds in parallel, will keep You updated if make some progress...
Message 13 of 14
(3,445 Views)
Attached working proof of concept with LabVIEW CLI, To make it work:
  • Disable Error message on logger instance (FGV in C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI\Operations\Utilities\Logger)
  • Enable multiple instances of LabVIEW
  • Spawn few labview processes that will run Builder.vi and pass instance parameter eg \..\..\Labview.exe \..\..\Builder.vi -- 1
  • Copy ExecuteBuildSpecAsync_class folder to C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI\Operations
  • Start it the same way from labview CLI but use ExecuteBuildSpecAsync insstead of ExecuteBuildSpec, should compile on free running builder or throw exception
It seems that LabVIEW CLi opens 1 new instance and always connects to it (just my observation so far)
Message 14 of 14
(3,431 Views)
