Continuous Integration
Running Sequence Analyzer Stand-alone application with Azure DevOps agent
Has anyone tried to run Sequence Analyzer with a build agent, Azure DevOps in particular?
I get this error when I try to:
Unhandled Exception: System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
   at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
   at AnalyzerApp.e.a(String A_0, String A_1)
   at NationalInstruments.TestStand.Utility.LaunchTestStandApplicationInNewDomain.HandleLaunchProtectedException(Exception e, String applicationName, DisplayErrorMessageDelegate displayErrorMessage)
   at NationalInstruments.TestStand.Utility.LaunchTestStandApplicationInNewDomain.LaunchProtectedReturnCode(MainEntryPointDelegateWithArgsReturnCode entryPoint, String[] args, String applicationName, DisplayErrorMessageDelegate displayErrorMessage, Boolean parseArgs)
   at AnalyzerApp.e.b(String[] A_0)
Message 1 of 1
(3,586 Views)
