Counter/Timer
2 channel continuous pulse train generation and frequency changed on fly pci-6723
Hi
i am working on pci-6723 ,i would like to generate 2 channel continuous pulse generation , and frequency can be changed on fly .how can i use daqmx write in this case , kindly put a reply please
windows 2000 os
labview 7.1
Thanks and regards
rajesh
(3,590 Views)
Rajesh,
This vi will help you get started. It is not writte specifically for your board, but it will be a great start.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=E3B192743B3A64BAE034080020E74861&p_node=DZ52313&p_source=External
Anuj D.
(3,577 Views)
Hello Rajesh-
I've attached an example that shows how to change frequency and/or duty cycle on-the-fly during a continuous pulse train generation with counters. It is a modified version of the example posted in the development library - NI-DAQmx Pulse Width Modulator. Rather than using property nodes, it uses the DAQmx Counter Write.vi. Either method will work for you.
I hope this helps!
gus....
(3,564 Views)
