Counter/Timer
-200141 error thrown when sampling a high frequency signal on usb-6281
I have a USB-6281, and I am attempting to use it to timetag the pulses from an excelitas APD. However, when I attempt to use a counter with an 80 MHz time base to measure the period between each pulse (one counter), the error -200141 is thrown. If I try to do the same task for 2 counters high frequency, the error is also thrown if the measurement time is less than around 5 microseconds. I am wondering if there is some way around this error? Thanks?
(1,765 Views)
That can be a tough one.   Let me start by referring you to this thread, then come on back.
1. Somewhat surprisingly, the much cheaper USB-6210 supports much higher sample rates for counter tasks.  This is because of its much larger onboard FIFO -- 127 samples instead of 2 samples for the 6281.
2. The combo of a tiny little 2-sample FIFO *and* USB limits you even more than if you had a PCI or PCIe desktop 6281.
3. As discussed in the referenced thread, if the error arises as a result of "false edges" due to noisy transitions, a digital filter could help.  But your mention of a 5 microsecond accumulation time makes me suspect that your real pulse rate is simply too high for your hardware to keep up.
    What *is* the highest pulse rate you can expect to see?  And what's the pulse width of the signals produced by the APD?
4. Other than brief experiments, I've never really used the 2 counter freq measurements.  Does your mention of 5 microsec measurement time mean that you were trying to operate at a 200 kHz sample rate?
   Unfortunately, it doesn't surprise me that 200 kHz would be more than your device can sustain due to the combo of USB and 2-sample FIFO.
Do you have access to any other data acq devices to use for this app?  The best candidates would be devices with a bigger counter FIFO, such as the USB-621x or the 63xx (either USB or PCIe).
-Kevin P
(1,733 Views)
Hi Kevin,
thanks for your help! Because of the samples we use, the APD will spit out pulses of width around 10 ns at a frequency of around 1.2 MHz all the way up to 10 MHz on extremely bright samples. I believe the APD has a deadtime of around 22 ns, so I probably need a DAQ that could cover the full range of frequencies.
(1,712 Views)
Sorry I meant to say 120 kHz, that factor of 10 is absolutely huge!
(1,689 Views)
