Counter/Timer
3 quadrature encoders on one 9411
I'm trying to read three quadrature encoders using a 9411 in a cDAQ. In the cDAQ is a 9437 reading a load cell.
Sample rate is set to 1613 HZ, and the counters use the cDAQ/ai_clock .
Reading one encoder on DI0a/DI1a, I have no problems. As soon as I add a second encoder on DI2a/DI3a, I begin to get strange results. It's as if the position skips or jumps occasionally.
I guess before I start troubleshooting I'm wondering if there is any reason I should not be able to measure three quad encoders using the 9411.
The three encoder readings are three different tasks. Perhaps I should make them one task? These tasks are all read in a loop, 20 readings at a time, but they're reading in parallel.
Using LV2013, Win 7.
Hoping to get some advice on the code.
Jeff
(6,182 Views)
Sorry I was an idiot! The 9411 was missing the ground wire at pin 12!
(6,154 Views)
I'm interested in your code, could you please save it in an earlier LV version, e.g. LV2011.
(6,140 Views)
Sure! Keep in mind that I'm not a pro at Labview. See if this works for you. Should be in 2011
(6,137 Views)
