Counter/Timer
6023e PMT pulses counter
Hello
I m trying count the pulses that cames from a PHOTOMULTIPLIER (PMT) when I use a counter0 to count during for example une second I dont have any kind of problem. The problem appears when I want gate this counter with the output of the counter1. For example if I creat a square wave with duty cicle of 0,5 ,frequency of 10000 and the number of samples per chanel of t 10000  and if I use this sqare wave to be the gate of the counter0 I have a number of counts completly diferent for the case when I use only one counter during une second(a big big value comparativetly to the case where I use only un counter). Where can be the problem and how can I solve it?The reason why I want use the counter1 as a gate is because I wante have information of the number of pulses vs Time during for example une second.
(5,980 Views)
Hello.
Could you post the application you use to do that?
Thank you
(5,966 Views)
