Counter/Timer
6218 only one of two counters works
All-
    I am using the two counters on my USB 6218 simultaneously.  Counter 0 works, while counter 1 does not for the standard input.  When I switch counter 1 to the timebase, it counts the timebase fine.  When I switch it back to the standard pin (PFI3, I believe), it does not count my pulses.  However, this same pulse source counts fine on counter 0 on its standard pin.  Any suggestions?  It worked fine, but now I have changed computers (and no longer have access to the old one).  LV 2013, daqmx15.?.?  J
(2,499 Views)
I'm not sure I understand 100%.  Here's what I think I've gathered:
1. Both counters are doing edge counting
2. There's some kind of external pulse source.  (Or sources?).  It's wired into the default source input for Ctr 0 (PFI8, according to MAX pinouts for a simulated M-series device).
3. It's unclear what, if anything, is physically wired to Ctr 1's default source input (PFI3 according to MAX).
4. Ctr 0 counts successfully, Ctr 1 doesn't.
5. When you configure Ctr 1 to use an internal timebase as its source signal for counting edges, then it *does* count fine.
If I've got that right, then the next thing I'd do is configure Ctr 1 to count edges on the signal that Ctr 0 is also counting.  That's allowed, 2 tasks can both count edges sourced from the same PFI pin.
If that works, I'd suspect there's a conflict or oversight between the physical wiring in place for Ctr 1's pulses and the task configuration settings that define what Ctr 1 should count.  Maybe the signal is wired to a pin *adjacent* to PFI3 or something like that.
-Kevin P
(2,485 Views)
Kevin,
    Thanks so much for your reply.  It seems that the whole incident was precipitated by a flaky cable.  You may now berate me for ineffective troubleshooting.  J
(2,470 Views)
