Counter/Timer
6251 Counter input signal
I am acquiring pulses which are 0-5V with the counter of the PXI 6251. However, I would like to know if it is possible to acquire pulses that are, for example 0-12V or 0-24V without damage the device. In other words, which is the voltage range for the counter input in a PXI 6251?
thanking in advance,
CJMV
(3,963 Views)
Hi!
If you watch the specification, you can see, that the counter has only TTL Logic. Every voltage which is higher can damage you device:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14125
There is no possiblility to connect higher input voltages.
Greetings,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,947 Views)
You will not be able to use the counter directly but you can setup an analog level trigger for your signals. This will create a pulse that isTTL compatible  for you everytime the signal crosses a particular level. Then you can route this into your counter and perform any counter measurements on it. An example is this is shown here where it sets up a level trigger to make frequency measurements.
Alternatively you can purchase an industrial strength digital I/O board such as the USB-6525 but this does not include a counter.
Please let me know if this works out for you.
Message Edited by Abhinav T on 07-06-2007 05:20 AM
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,941 Views)
