Counter/Timer
6323-counter output -from external input
Thank you
So i won't need a Gate input signal to run the countnuous output?.. I do not have my DAQmx Card yet to try it out ,unfortunately, but I wanted to be ready.. it's on back order
In one of the Vi's, I see the DAQmx Vi, there is a Connect Terminal source to dest.. Have u worked with this ? Will this send source PFI pulse to des tination PFI without the need of going through counter. See attachment.
Message 11 of 16
(1,877 Views)
No you won't need a Gate signal to run the continuous output.  The "gate" is open by default.  But for future reference, in DAQmx an enable/disable type of "gate" is termed a Pause Trigger.
I haven't worked with DAQmx Connect / Disconnect Terminals (see my previous msg #8) as I've generally preferred to do my signal routing from within a task context with DAQmx Export Signal.  But my understanding from things I've read is that:
- yes, it would route a signal from a source PFI to a destination PFI
- however, it would need to consume one of your device's counters in the process.  I don't know how DAQmx chooses which one, but I don't think there's a way to specify.  I think it just picks from what's available.
But again, as I also said in msg #8, why?  Wherever you intend to physically wire that "destination PFI", why not just physically wire to the "source PFI"?   The kind of signal duplication you're talking about isn't usually going to be necessary or particularly helpful, especially for systems that haven't already been wired up.
-Kevin P
Message 12 of 16
(1,859 Views)
To answer the question, This is part of an already existing Station Test. The ctr0 (out) feeds ctr1 ,ctr2 to exercise and verify all counter operation with a scope.
Message 13 of 16
(1,851 Views)
I had a chance to do a quick test with DAQmx Connect Terminals.
1. The good news -- it appears to replicate the source terminal signal onto the destination terminal.  I don't try to figure out how much the delay there might be (if any) between source and destination.
2. One of the device's available counters gets consumed to accomplish the routing.  In my really brief test, DAQmx
seemed to use the highest-numbered counter that wasn't already reserved for other another task.
-Kevin P
Message 14 of 16
(1,782 Views)
Thank you for trying it out. I won't have the hardware till later in the year, so it is much appreciated.
Message 15 of 16
(1,777 Views)
using 6323 counter - continuous output.
I would like to have 2 counter output (cntr0,cntr1) going at the same time. It seems like when the  Counter-countinuous Output - stay on. vi (below ) is done, the output turns off even if I did not call the stop task...I will call the .vi 2x- once for each counter
Is there a way to keep ctr0 and ctr1 going after the .vi are done ?
Message 16 of 16
(1,460 Views)
