Counter/Timer
6602 internal clock 80 Mhz
Hi
How can I use the 80 Mhz internal clock in a PXI-6602.
There is no ND_INTERAL_80_MHZ define in the nidaq header file.
(4,276 Views)
Greetings,
To leverage the internal 80MHz clock in the PXI-6602 you should use the parameter ND_INTERNAL_MAX_TIMEBASE.
Justin Britten
(4,275 Views)
We have tried this with the parameter ND_INTERNAL_MAX_TIMEBASE (in visual C++) and it still doesn't work ... Is there any other solution, at least there should be one ...
(4,252 Views)
It should be working. Perhaps you could post some code that you are using so we can see what you are doing.
-Sal
(4,241 Views)
See the following link (same subject)
http://forums.ni.com/ni/board/message?board.id=40&message.id=374
(4,234 Views)
