Counter/Timer
6602 interrupt programming
I have started writing a driver for the NI6602 card (since one does not exist in Linux) and have been using the register level programmer manual as a guide.
I want to use the card in a mode as described in the manual (p. 2-4, Buffered Cumulative Event Counting). I have been able to configure the card to start a counter, and have sucessfully read the HW and SW Save Registers while it is running.
What is the "method" for having an interrupt created on a HW Save (due to a rising gate edge)? I can read the HW Save register after I have created a pulse on the selected gate, but my interrupt handler is never invoked.
I am guessing that some more configuration of the MITE needs to be done, but I can't find any documentation on that.
Also, the "Interrupt Acknowledge" register description seems to be lacking from the manual.
Is there more documentation floating around on any of this?
Thanks...
-Rob
(3,850 Views)
Rob;
Unfortunately National Instruments doesn't support Register Level applications.
I suggest you to go to www.ni.com and type +register +level in the search field to get access to all documentation posted on line about that topic.
Regards
Filipe A.
(3,850 Views)
