Counter/Timer
9188 sample clock for Example VI
   I'm trying to run the Example VI: "Gen Event for Ext Signal" on Labview 10 with the NI cDAQ 9188. I'm getting an error (see below). I tried fixing this error by changing the code from "Hardware Timed Signal Point" to "Continuous" but then it seems my sample clock doesnt work. Any ideas what's going on?
Error -200077 occurred at Property Node DAQmx Timing (arg 3) in DAQmx Timing (Sample Clock).vi:2->Gen Event for Ext Signal.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampQuant.SampMode
Requested Value: Hardware Timed Single Point
You Can Select: Finite Samples, Continuous Samples
Task Name: _unnamedTask<296B>
(7,025 Views)
it appears my 9188 does not support Hardware Timed Signal Point... as seen from this link:
https://www.ni.com/en/support/documentation/supplemental/18/daq-devices-with-hardware-timed-single-p...
Perhaps there is a way around this? I'm not getting the code to read my trigger when I change to Continous mode...
(7,024 Views)
Hi there roto,
Does the following link help?
NI-DAQmx Hardware-Timed Single Point Support for Oversample Clock Timed Devices: http://zone.ni.com/devzone/cda/pub/p/id/1325
Best,
Ryan C.
(7,005 Views)
thanks for the tutorial, that should be very useful, but my 9188 doesnt seem to support hardware timed single point. Is there something I can buy that is cheap and simple that I can add on to this system to get this functionality? I'm currently using a labtop connected to the 9188 which then connects to the digital output pins of a 9401.
(6,980 Views)
Hi roto123,
Most USB and Ethernet devices don't support Hardware-timed Single Point--the feature just isn't very useful when you are on a non-deterministic bus.  Could you let us know more about the big picture of your application and what you are trying to do with the hardware?
Best Regards,
John Passiak
(6,972 Views)
