Counter/Timer
9361 counter differential input
I want to use the differential input capability of the 9361 counter for an angular encoder application that has noise issues. The manual shows that the digital input circuitry has a switch that can be configured for differential input, but does not explain how to set this up. This function is not available either through MAX channel setup nor through Labview channel property node parameters. How can I set up the 9361 counter inputs for differential use?
Neil
Message 1 of 1
(2,960 Views)
