Counter/Timer
9401 clock source for angle measurement
Hello
I have a NI9401 on a C-DAQ9178 on slot 5. One encounter is connected to the 9401 and i created a task for the angular position measurement.
My problem is that I want to have continuous samples but I din't get the right clock source, so only 1 sample on demand works currently.
Does anyone have an idea how to configure the clock source?
Thank you very much in advance,
Martin
(6,313 Views)
Hello Martin,
there is an internal frequency output that can be used for the clock.
Attached an Example hope this helps
best regards
Alexander
(6,304 Views)
Hi Duffy,
thanks for the vi. I think I understand now how it should work, but my problem is that I have to configure it in the MAX, because I've to use the signal in DasyLab, and this doesn't work. If i select continuous data in the task, i have to select a clock source under Advanced Timing and none of them works.
(6,274 Views)
Hello Martin01
so the situation is, in that case, the aquire only can be done with the samplerate from DaisyLab.
Sorry for this, but you can´t implement the continous feature like in our task described.
best regards
Alexander
(6,226 Views)
