Counter/Timer
Accuracy of frequency generation
Hi all!
I have a 6602 and wondering how accurate this DAQ card can generates  a frequency of 432,292229547 Hz ?
Thanks in advance
Vu
(3,904 Views)
Using the 80 MHz timebase, you can get generate frequencies f_x = 80 MHz / i, i =4, 5,.....The closest you can get this devided timebase is 432.29 Hz I believe. The timebase stability is 50 ppm which means that the accuracy in this case would be +/- 0.02 Hz.
Hope it helps.
Pelle S
Account Manager
National Instruments Sweden
(3,883 Views)
Hi Pelle !
Thank you for your answer, it's help me a lot.
Best Regards,
Giang Vu
(3,873 Views)
