Counter/Timer
After loading driver, I am missing slew of dlls which are present on the disk
I am attempting to reinstall in-house written (but long ago in a faraway land by a possibly mythical programmer) software on an XP system, which is supposed to allow a PCI-6602 to communicate with an SCB-68. The drivers (DAQMX software for windows v. 8.5) appear to load just fine, but when I run the application, it whines about missing a whole slew of dlls which are not present in v. 8.5. They are present in v. 6.9.3, however. I have tried uninstalling 8.5 and installing 6.9.3 - and the application still whines about the missing dlls! Although they are present on the disk, they do not get installed when the DAQMX software installs itself. I can't just copy the files in question from the installation disk, because there are a lot of them, and most, if not all of them exist in 2 or three different versions each: e.g. nidaq32.dll.SOME_RANDOM_CODE, nidq32.dll.ANOTHER_RANDOM_CODE. I guess I *could* copy them, of course, but the number of possible combinations is daunting, and I feel sure there is a more intelligent way to figure this out.
(4,823 Views)
Accepted by topic author CluelessSue
Hi Sue,
        nidaq32.dll is associated with the NI-DAQ traditional driver, so I'm wondering if the program could have been written before DAQmx was introduced.  What version of LabVIEW was your program written with?  Also, you may want to verify that you need the Traditional NI-DAQ rather than the DAQmx for your program.  If you have your NI-DAQ CD, install the traditional driver with all of the support.
Good luck!
AnitaB
Message Edited by author support on 12-22-2008 12:06 PM
Anita B
(4,808 Views)
