Counter/Timer
Any ideas on how to use a 6602 to do frequency division?
Uisng traditional DAQ.
The 6602 user manual says it can do frequency division but I can not find an shipping example for this operation.
In the end I want to be able to use the 6602 to handle the interface to a quadrature encoder.
I want the 6602 to generate a sample pulse I can use for other DAQ work.
I would like to get one pulse for both transitions of both the A and B signals, or otherwise stated;
A pulse when
A goes high
B goes high
A goes low
B goes low
I was thinking if I could configure a counter (or group) to operate as a frequency divider and use each of the encoders as a clock signal AND just do a divide by "1" I would have what I was after.
Big Picture (incase it makes a difference)
A quadrature encoder is coupled to a resolver I am testing. I need to corelate the angular displacement with the measurement from the resolver. While the shaft of the encoder and resolver are spinning, I want the encoder to clock the analog input samples.
Thank you for reading,
Ben
(3,656 Views)
Ben,
First the executive summary: Sorry, No Can Do.
You won't be able to generate a sampling clock pulse on the transition to each of the 4 quadrature states.   Here's a thread I was involved in where a similar question was asked.   If you need to correlate in exactly that manner, you may want to pick up a quadrature decoder chip such as the 7084.  It'll generate a "pulse" whose width is controlled by selection of an RC time constant during circuit build.  I put "pulse" in quotes because it isn't truly a TTL signal due to the long transition time.  I would recommend that you plan on adding a Schmitt trigger to square it up, perhaps another to re-invert it back to original polarity.
However, all that being said, you may be better off using an internal sampling clock to drive analog and encoder position acquisition anyway.  On many encoders I've used, the transitions are NOT perfect 1/4 divisions of the cycle.  You can sometimes see this on the spec sheets where the A to B relative phase is given as, say, 90 +/- 15 degrees.  There will also be a tolerance on the phasing of A's rising and falling edges, maybe 180 +/- 10 degrees (it's often a little tighter than the A to B phasing).
In practice, I've typically found that these deviations tend to be systematic rather than random.  Of the company's 1000 similar encoders, the phase stays within the range 90 +/- 15.  With my 1 instance, the phase may be 84 +/-3 around a full rev of the encoder.  The point is that if you generate pulses with the quadrature transitions, the samples still won't *really* be equally-spaced in position.  They'll just think they are.
I'd suggest at least considering high-speed sampling with an internal clock that's shared by both tasks.  Then do a little bit of curve-fitting / interpolation to the data when you need to derive more precision.
Re: frequency division.  You have to select a specific edge (either rising-only or falling-only) as the active edge.   Your counter will then ignore the other type of edge.  Also, you'll need to specify the # of edges each for the idle and pulse states.  These must each be >= 2.  So you can't divide by 1 - the best* you can do is to divide by 4.  (*Technically, you could sort-of divide by 2 if you configure the counter to pulse rather than toggle its output.  However you can't control the pulse width, and as I recall it's fixed at 50 nanoseconds.)  Write back if you'd like to see an example.
-Kevin P.
(3,647 Views)
Hi Kevin,
I was hoping you would respond.
Excellent points re: the phase of the A & B signals. That settles it even if my dream was real.
Ben
Now if I could give you more than 5 stars.....
(3,643 Views)
