Counter/Timer
Bonjour, How generate 4 signals synchronized with PCI 6601
Bonjour,
A l'aide d'une carte PCI 6601(Counter/Timer) qui possède 4 compteur et de NI DAQ 7, on souhaite réaliser des trains d'impulsion (voir description jointe) à partir de Labview 6.0. On veut pouvoir régler le nombres d'impulsion, la période, le rapport cyclique et le déclenchement à partir d'un bouton sous Labview pour que l'ensemble des signaux soient synchrone. On souhaite générer ses signaux sur les 4 sorties de compteurs.
Merci
Using a chart NCV 6601(Counter/Timer) which has 4 counters and Ni DAQ 7, one wishes to produce trains of impulse (see joined description) starting from Labview 6.0. One wants to be able to regulate the pulse repetition frequencies, the period, the cyclic report/ratio and
release starting from a button under Labview so that the signals are synchronous. One wishes his signals on the 4 exits of counters.
Many thanks
(3,282 Views)
Please have a look to the web page below:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E18156A4E034080020E74861&p_node=DZ52328&p_source=External
This example generates multiple pulse trains from a 660x counter/timer device. You will need to install the counter palette upgrade to add multi-counter VIs to your LabVIEW palette.
Regards.
(3,282 Views)
