Counter/Timer
CPU resources not released with 6602
I am performing continuous semiperiod measurements using a PXI 6602 timer card, along with other DAQ boards (6259...).
The cards are installed in a PXI rack and driven by a 8196 real-time controller.
Our system also acquires digital & analog inputs, as well as generating the same kind of signals. I discovered that from run to run, CPU usage was growing, and I spent quite a lot of time to point out it was due to these semiperiod (PWM) measurements.
Basically, we configure once our system to create appropriate DAQmx tasks, and we start/stop these tasks when needed. When measuring more than 3 PWM inputs (e.g 4 timers of the same 6602 board), I observe through the Real-time System Manager that the CPU usage is increasing each time I restart the tasks.
In top of that, if I clear the PWM DAQmx task and restart the other ones (AI, DI...) this "ghost" CPU usage is still present ! Smiley Mad
The only way to remove the problem is to reset the 6602 card (note that resetting only this one is sufficient, so the problem is not linked to the other cards).
When running the system quite a long time (and applying several DAQmx start/stop), it can lead to almost 100% CPU usage and plenty of RT cycle lost. Very annoying... Smiley Sad
I created 2 VIs to reproduce the problem. As it is a very limited configuration, it is necessary to stop and resume many times before observing this CPU increase. This is generally coming more quickly when using a Timing Loop using hardware counting (Semiperiod measurement - HW TL.vi) but I also saw it running the second example (Semiperiod measurement - SW TL.vi). Using a combination of DMA/IRQ transfers also shows the issue more easily.
Please also note that this problem occurs even if I do not connect input signal to the 6602 card.
Anyone got a similar problem ?
It really looks like an issue of the DAQmx driver for buffered continuous semiperiod  measurements...
Message Edité par Inpriser le 06-13-2006 09:02 AM
(4,205 Views)
Another issue appeared, when creating DAQmx tasks and starting them, I sometimes get the following error message on controller video output :
System Error KERNEL.446580 : Illegal Win32 API called from a hardware ISR.
Fatal error KERNEL.146070 : Out of interrupt stacks.
ETS Monitor halting with error code 1.
What is wrong with these interrupts ? I just try to use all of these timers out of this PXI 6602 board...
Does anyone got an idea ? It is not the first time I use this kind of card, but now using it along with a real time controller additional issues seem to arise.
Thanks for help
(4,188 Views)
Be sure that you have the last driver's version:
NI-DAQmx https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
Do you have also the last version of LabVIEW, and LabVIEW RT?
This error message comes each time you use the 602 device?
Sanaa T
Sanaa T.
National Instruments France
(4,136 Views)
