Counter/Timer
Can I use four separate encoders on 9401
Hello! I am working with  cDAQ 9178 with a 9401 card. The chassis and the card have access to four counters and I need to read from four separate encoders. So, I need access to all four counters. I see in the pinout for the 9401, that the counter pins overlap (see screenshot). For example, pin 20 is the A channel for counter 1 and is simultaneously the B channel for counter 3. Is it possible to still use all four counters at the same time since I would need to wire channels on multiple encoders to the same pin?
(931 Views)
No screenshots were attached.
Anyway, running four counter input tasks on the NI 9401 should work (Reference: Re: Measuring 4 counter inputs through NI 9401). You can assign any digital line as the A and B signals for the encoder. You can refer to the shipping examples. See How to Search DAQmx Examples in LabVIEW
https://tmesystems.net/
(896 Views)
Thank you so much for the response! I have reattached the screenshot of the pinout. My big concern is that I need 12 inputs for the four encoders (3 per). The 9401 card only has 8 digital ports which is why some of the pins overlap on the various counters. So, regardless of how I configure the channels, there will still be some overlap. I was wondering if it is safe/feasible to maintain the independence of the encoders if some of them are connected to the same physical pin but different counters. Thanks in advance!
(888 Views)
You can use 4 counters only if you don't use the Z signal. If you need the Z signal, one 9401 can only read 2 encoders.
(862 Views)
