Counter/Timer
Can the TTL inputs of my 6602 be damaged by low but negative voltages?
I am interested in using the counters of my 6602 board to measure the frequency of a sine signal. I could convert the signal to a TTL compatible pulse signal, but was wondering whether I could simply hook up the signal without doing this. The input voltages would be low (<4V pk-pk), but I seem to recall that TTL inputs can be damaged if the voltage goes negative. Would it damage the board to try this?
(4,280 Views)
Hello Travis,
National Instruments does not recommend giving an input voltage less that -0.3V. How much less can the board can take is another question and it might vary. I would not try any voltage less than -.3V
Arun V
(4,280 Views)
Hello there ... though this thread is quite old ...
I am doing the same, using a 6016 DAQ and a pulse generated through a schmitd trigger from a sinewave
I get a peak negative voltage of -0.3 V and it works fine and the limit in the NI6016 is 0V. In the 6602 it is -0.3V, so therfore you should not have much trouble.
(3,874 Views)
