Counter/Timer
Changing frequency of the pulse train output to USB 6210 daq card
Dear all,
I try to control the speed of a stepper motor using USB 6210 card(s), I would like the speed of the stepper motor to change in a sin waveform.  Should I input the counter with an array of sin waveform data points repeatedly, or update the frequency in a timed-loop dynamically using a sin function varying with time?  Any suggestions or comments is highly appreciated.  Thank you very much.
best,
Ian
Message 1 of 1
(3,579 Views)
