Counter/Timer
Changing the PXI-6624 Counter Output rate on the fly
I'm programming an application in VB.net 2005 to set several counter output channels (each with its own task) on the PXI-6624 card. I'd like to know if there is a way to change the frequency of the output without stopping the task, changing the frequency and restarting the task. I'm using the PXI-6624 card to simulate encoders and speed sensors.
Thank you very much,
JonS101
(3,531 Views)
Yes, you can change the frequency on the fly. Here is a knowledgebase that will give you an insight of how you should approach this matter. How Can I Change the Duty Cycle on My Continuous Pulse Train?
I hope it helps
Jaime Hoffiz
Product Expert
(3,513 Views)
