Counter/Timer
Connect PWM Compass Modul CMPS10
For my Bachelor Projekt i have to work with an NI USB-6210 Device.
I want to connect an Compass Modul (CMPS10  Docu: http://www.robot-electronics.co.uk/htm/cmps10doc.htm) to this device.
I've Connected The PWM Output Pin with Pin1(PFI 0 alias CTR 0 SRC).
I want to record the Impulse width in ms.
My Problem is how to configure LabView/the USB-6210 Device to Record this Values.
Hope somebody can help me.
best regards Andre
(6,335 Views)
Hi Andre,
here are two links that might help you with your project.
Creating a Task in NI-DAQmx and Using it in LabVIEW
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/tasksnidaqmx.html
Kind Regards,
JoLe
Applications Engineering
(6,315 Views)
