Counter/Timer
Could I use PCI-6601 to generate a 200Hz clock based on a external 40kHz clock?
That means I want to use PCI-6601 as a frequency divider. (40KHz->200Hz)
Is it possible? Is there any example I can refer to?
(3,544 Views)
1. Yes it's definitely possible to make such a frequency divider.
2. Here are a couple links that may help:
http://forums.ni.com/ni/board/message?board.id=40&message.id=3607&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=78359#M78359
http://forums.ni.com/ni/board/message?board.id=40&message.id=4232&requireLogin=False
-Kevin P.
(3,526 Views)
