Counter/Timer
Count Digital Events with Pause Trigger [ Count only for certain no. of triggers ]
Hi All,
 I have PCIe 6320 and I am currently using "count digital events with pause trigger". If I only want to count for 5 trigger, how should  I do? Thanks,
(5,478 Views)
Hello thoo,
I would suggest taking a look at the Count Edges (Finite).vi in the LabVIEW Example Finder: Help » Find Examples » Hardware Input and Output » DAQmx » Counter Input. You can select how many edges to count in the Sample Clock function.
Does this help?
Cameron Schaefer
(5,456 Views)
