Counter/Timer
Counter Value to Time Signal
Hi all,
I am trying to do the following with an 6036E: I want to measure an angular position/rotational speed with the two counters andturn the output of the counters into waveforms. However to do that, I need the rate with which the the counter is polled (I think), however the property nodes for the DAQmx Tasks give me nothing. So basically I want for example angle over time.
Anybody got a quick solution to this minor problem?
George
(3,989 Views)
Hi George,
do you use LabView for this?
Mike
(3,979 Views)
Oh sorry,
I was so excited I forgot that piece of trivial information ;-). Yes, I am using LabView
(3,976 Views)
