Counter/Timer
Counter Wiring
I am not sure if I am using the right pins for counter.
I read a similar post (https://forums.ni.com/t5/Counter-Timer/Wiring-PXI-6624/m-p/855482#M7163) posted by another user, that helped me to understand but still I am not fully sure. So I am posting my issue below.
I want to measure the pulses produced by a Hall sensor.
The following connection diagram is the method by which we have wired the NI PXI6624 card via SCB-100 box. I want to know if this method is correct.
I am using CTR 0 Source+ and CTR 0 Source- as signal input points but not sure if we need to connect some trigger on CTR Gate , CTR AUX ....
As per the datasheet:
We have used the reference of the following diagram/ method from the user manual of 6624 card.
Sensor specifications are as shown below:
Please let us know if the signal connections are done correctly. As per Fig 1.
Message 1 of 1
(2,244 Views)
