Counter/Timer
Counter of PCI-6052E
what is the max frequency i can get from the counter of PCI-6052E and what is the max frequency wave i can use the counter to test ?How to calculate it ? Thanks a lot!
(3,491 Views)
The maximum pulse train output frequency is 1/4 the frequency of the internal timebase in "toggle" mode, or 1/2 the frequency of the internal timebase in "pulse" mode.  The PCI-6052E has an internal timebase of 20MHz, so the max output frequency is 5MHz or 10MHz, depending on the mode.  As far as a frequency measurement, that device should be able to measure a signal with a frequency as high as its internal timebase.  However, as the signal approaches the timebase, the accuracy of the measurement decreases.  Here is a good resource for frequency measurement considerations:  Making Accurate Frequency Measurements
-Alan A.
(3,436 Views)
