Counter/Timer
Counter output appearing on multiple PFI lines
I am trying to use the counter to output a digital pulse (continuous) on a select PFI channel.  This is easy enough, but I am observing some strange behavior.  If I select PFI0, then it outputs as expected.  But now, if I select PFI1, then both PFI0 and PFI1 output the same digital signal.  What I want to do is control which line outputs the signal, not have multiple signals going out at the same time.  I tried resetting my USB-6212 device, but that didn't seem to help.
(1,374 Views)
I don't recall details of the solution or workaround, but the search term to get you on the path is "lazy uncommit."
-Kevin P
(1,365 Views)
