Counter/Timer
Counter that triggers off the rising and falling clock edges?
I've got an interesting problem of a device that flips its state between high/low everytime an event happens (so two events make one complete cycle).  I'd like to clock an E series synchronously with it, but looking at the documentation I can't see anyway to tell a PFI input or counter to generate a new clock cycle on both the rising and falling edge.  Instead, it just generates a new cycle at half the actual event rate.
I realize I could generate a new clock at approximately the same frequency using the internal timebase, but unfortunately any jitter between the two clocks must be very, very small (<5 ns) for my application to work and the internal time base doesn't have great resolution.
Is there some obvious solution I'm missing ?
(6,167 Views)
Nope, E Series can't do this.
Many newer DAQ cards support a feature called "change detection" for digital I/O timing that could be used to generate a sample clock every rising and falling edge of your external signal (you could then export this sample clock or use it for another task).
You should probably elaborate on exactly what you mean when you say <5 ns jitter though, because this timing requirement is probably going to rule out using these devices anyway.
Best Regards,
John Passiak
(6,151 Views)
Can the X series board do this?  I could probably dig one up somewhere.  Is there example code somewhere showing how to use it?
This is an imaging application, where the trigger is basically the line trigger, and the data are the pixels.  The pixel rate is 100MHz, thus I would like my jitter to be less than 0.5*(1/100MHz) = 5 ns so that I don't have any pixels inadvertantly shift from the back of line to the start of the next due to timing errors.  The actual trigger rate is quite low (< 10Khz).  Its just a very wide image I'm reading in.
Thanks.
(6,148 Views)
What is the DAQ card's role in this application?
Best Regards,
John Passiak
(6,138 Views)
Nevermind, turns out Alazar's boards can trivially do this, so no need to involve NI at all.
(6,131 Views)
