Counter/Timer
Counter to generate event after certain counts
Hi everyone,
I would like to use my PXI card to generate an event (to my software) every say, 100 counts(for 100kHz Timebase). In other words, is it possible to generate an event every 1 ms based on the counts on the counters.
 Also, is it possible to reset this counter based on the GPS 1 PPS? I wanted to sync this counter with the incoming GPS PPS. Thanks!
YB
(4,156 Views)
It is possible to reset a counter using a boolean input. If you could convert you GPS PPS signal to a boolean array, this idea applies.  I'm linking a knowledgebase article that demonstrates how to reset a counter. It should be very useful in getting you started.
http://digital.ni.com/public.nsf/allkb/65E3DBC715998C3286256E900075B7F8?OpenDocument
Best wishes,
Wallace F.
(4,115 Views)
Thanks for the help. I am reading the link you posted and is experimenting with the suggestion. I will update the progress once I got it right. 😃
YB
(4,080 Views)
Could you tell me why I got an error ("You are not authorized to view this document") when I clicked on the above link?
thanks,
(3,348 Views)
