Counter/Timer
Counter voltage threshold?
I have a signal that is only outputing a range of voltage from 0.5V to 2.8V.  This does not seem to be triggering the counter.  A different encoder with 0-5V is working great.  Any way to change the voltage threshold?  I'm using NI-DAQmx from visual basic on an NI USB -6251.
Karsten Wilson
Hewlett Packard
karsten.wilson@hp.com
(7,447 Views)
I also want to do this activity....
Pictures of Bed Bugs
(7,430 Views)
There is a hardware solution and a software solution. The hardware solution involves using a zener diode to shift the thresholds based on the breakdown voltages. This is described briefly in the article <link no longer exists>. The software solution would be to use an Analog Input task, and do a software compare and generate the counter events based on implementing some processing on the analog signal. A good example of this would be the Analog Input Threshold community example.
- Regards,
Beutlich
(7,400 Views)
For periode signals in the MHz range I just had tried this with success.
On a SCB68 screwboard  it was a free air construction 🙂 . I needed a 50Ohm termination, and the R/Cin_PFI are for Simulation only, and I a had lower amplitude.
Short modification.... not beautifull, but sim say it might work 😉
This is a 100kHz sim , blue your signal , green the collector voltage, however I didn't look at the soucre impedance!! Currently this is a low impedance source!
Greetings from Germany
Henrik
LV since v3.1
(7,394 Views)
