Counter/Timer
Counters Synchronization
I would like to synchronize the clocks of two counters to figure out the offset between them. Th floowing worked in Traditional, but not sure how to so that in NIDAQmx.
  //Set Up Clock Counter
  int Status = pGPCTR_Control(m_NIDeviceNumber, ulGpctrNum, ND_RESET);
  if(Status){
   AfxMessageBox("Could not Reset Clock Control.",MB_OK);
   return FALSE;
  Status = pGPCTR_Set_Application(m_NIDeviceNumber, ulGpctrNum,ND_BUFFERED_EVENT_CNT);
  if(Status){
   AfxMessageBox("Could not Set up Clock Buffering Event.",MB_OK);
   return FALSE;
  unsigned long Resolution = ND_INTERNAL_100_KHZ;
  if(m_NIClockResolution==1)
   Resolution = ND_INTERNAL_20_MHZ;
  Status = pGPCTR_Change_Parameter(m_NIDeviceNumber, ulGpctrNum, ND_SOURCE,Resolution);
  if(Status){
   AfxMessageBox("Could not Set Counter to internal Clock.",MB_OK);
   return FALSE;
  Status = pGPCTR_Change_Parameter(m_NIDeviceNumber, ulGpctrNum,ND_GATE,Gate);//ND_PFI_7);
  if(Status){
   AfxMessageBox("Could not Set Counter SCANCLOCK/PFI7 Pin",MB_OK);
   return FALSE;
  unsigned long Polarity = ND_LOW_TO_HIGH;
  if(HighToLow)
   Polarity = ND_HIGH_TO_LOW;
  Status = pGPCTR_Change_Parameter(m_NIDeviceNumber, ulGpctrNum,ND_GATE_POLARITY,Polarity );//
  if(Status){
   AfxMessageBox("Could not Change Polarity",MB_OK);
   return FALSE;
  Status = pGPCTR_Change_Parameter(m_NIDeviceNumber, ulGpctrNum,ND_INITIAL_COUNT, 0);
  if(Status){
   AfxMessageBox("Could not Set Counter to Zero",MB_OK);
   return FALSE;
  Status = pGPCTR_Change_Parameter(m_NIDeviceNumber, ulGpctrNum,ND_BUFFER_MODE, ND_CONTINUOUS);
  if(Status){
   AfxMessageBox("Could not Set Counter Buffering Mode",MB_OK);
   return FALSE;
  Status = pGPCTR_Config_Buffer(m_NIDeviceNumber, ulGpctrNum, 0,BufferSize,Buffer);
  if(Status){
   AfxMessageBox("Could not Configure Buffering Mode",MB_OK);
   return FALSE;
  Status = pGPCTR_Control(m_NIDeviceNumber, ulGpctrNum, ND_PROGRAM);
  if(Status){
   AfxMessageBox("Could not Set Clock Control",MB_OK);
   return FALSE;
  if(SyncToGpctrNum>0 && pGPCTR_Watch!=NULL){              //How do I get this done in NIDAQmx ???
   pGPCTR_Watch(m_NIDeviceNumber,SyncToGpctrNum,ND_COUNT,&watchValue);
   pGPCTR_Watch(m_NIDeviceNumber,ulGpctrNum,ND_COUNT,&watchValue1);
   m_NIClockOffset=(watchValue-watchValue1);
(5,451 Views)
Hi SoftwareGuy2009,
What hardware are you using?
Jim Schwartz
(5,421 Views)
Hi SoftwareGuy2009,
Could you give me an idea of what you are trying to do?   You can find examples for DAQmx at Start>>Programs>>National Instruments>>NI DAQ>>Text Based Code Support.  These will give you a good idea of how to use your device with DAQmx.
Jim Schwartz
(5,382 Views)
