Counter/Timer
Counting TTL pulses at high speed
Hi all,
I am using PCI-6221 board with DAQmx to count the number of TTL pulses (which varies in its frequency between 0Hz to 10MHz) at a high speed (200,000 samples/sec.) and I am having a problem when the TTL pulse frequency drops below a certain level.
I am using CTR0 to generate continuous pulse train at 200kHz frequency to feed to CTR1 Gate input. I verified that the pulse train is being generated fine.
I am using CRT1 with buffered counting to collect the count for 200,000 samples at a time (duration of 1 sec.). I got the example code (Cnt-Buf-Cont-ExtClk) and pretty much used it as is.
CTR1 Gate is coming from CTR0 Out, which is 200kHz pulse train with 50% duty cycle, and CTR1 Source is the TTL signal that I am trying to count. At first, I thought that everything was working fine with the Source signal being at around 5MHz. Then, when I had the Source signal down below about 300kHz, I noticed that the program is taking longer than 1 sec. to collect the same 200k samples. Then, when I got the Source signal down to 0Hz, the program timed out.
I am guessing that somehow the counter is not reading for the next sample when there has been no change to the count, but I cannot figure out why and how.
Any information on this and a way to get around would be greatly appreciated.
Kwang
(3,758 Views)
One thing you can try is to set the counter input CI.DupCounterPrevention property, this setting will filter the input, it is possible that when the ctr 0 is slow then many of the values you are counting become zero as well and are filtered out, since they are nolonger points, the counter will not collect enough points before the time-out occurs and the counter input read times out.  I am not sure if this is your issue but I found out the hard way that this occurs when I switched to daqMX where this feature was added.  Let me know if it worked,
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,754 Views)
Dear Paul,
I tried your suggestion and it works!
Thank you for your help.
Kwang
(3,748 Views)
