Counter/Timer
Counting pulses of wind speed sensor and rain tipping bucket
I have Omega Engineering's wind speed sensor and rain (tipping bucket) gage for the WMS-16.  The wind speed and tipping bucket pulse counter inputs are normally at 1.6 Vdc and are pulled down to ground by each switch closure.  I can input 5 Vdc and still detect a drop in voltage with each switch closure, so I think the 1.6 Vdc is just how the WMS-16 datalogger is setup (Omega never confirmed this, been very difficult to get specs on these sensors).  Seems to me I need the CTR-502, but I am confused if I am in need of a sinking (CTR-500) or sourcing (CTR-502) input type with these sensors?  Any help appreciated.
(3,963 Views)
What you are describing sounds like a sinking digital output.  So you are correct, you need the CTR-502 sourcing counter module.
Also, make sure that the voltage drop when the switch closes is enough to be detected.  (Specs)
I hope this answers your questions.
Justin Parker
Product Support Engineer
(3,941 Views)
