Counter/Timer
Counting the number of quadrature encoded digital pulses using a general purpose counter.
Hello, ALL
I work with DAQPad-6020E, using Measure Studio for VC++.
TASK:
I try to count the number of quadrature encoded digital pulses using a general purpose counter. Exactly I need to make it with 2 counters (X and Y coordinates of optical mouse).
STEPS:
At first I try use sample of NI library. But function
iStatus = GPCTR_Set_Application( iDevice, ulGpctrNum, ND_POSITION_MSR);
return error (-10120 - "Invalid application used")!!!
I change nothing in sample (CTR\TIOquadEncoderPosMeasure), so what's up?
Wait impatiently for your answer,
Alexey Potanin, NI beginner...
(3,553 Views)
E series cards have DAQ-STC timing controller. So you cannot use an NI-TIO based example with E series cards unless the examples are explicitly made for DAQ-STC/NI-TIO.
For encoder measurements with DAQ-STC, please take a look at the following links. It has example to do the Encoder measurements with DAQ-STC.
Encoder Measurements
Sincerely,
Sastry V
(3,553 Views)
