Counter/Timer
Creating a countdown timer
Hi, I'm back with more questions. I'm trying to figure out the best way to display a countdown timer. The idea is I turn on a power supply for a set time (Say 30minutes) and I want to be able to view in the program how much time is left. I'm using the Time Delay function to put in the delay between turning the power on and turning it off. Should I be instead using the elapsed time function, which seems to have a built in elapsed time output? Or can I use the time delay and get this to work as well?
Message 1 of 1
(1,690 Views)
