Counter/Timer
DAQmx 6601 interrupt mode
I bought this card as a counter, unfortunately it has only one DMA
(default) but 3 Interrupts:
(http://www.epics.org/cryomodule/3daqsc394-399.pdf)
I don't know how to use this mode (interrupt) in my vee program (I find on NI web site solution working on labview:
http://digital.ni.com/public.nsf/allkbC326F7D33CA6DB0E86256DFE008043B7?OpenDocument)
but i can't find it in vee.
(6,061 Views)
Hi Michalmm,
  If You are referring to Agilent's VEE, than the following link should be useful for You:
http://digital.ni.com/public.nsf/allkb/0024F410CA07C7AD86256C5200641B70
Here You might find information on using the DAQ dll in Your environment.
If You are not referring to Agilent's VEE, please give me some more detail on Your development environment!
David Varga
NIH
(6,033 Views)
Hi DavidVr and thx for replay,
I tried this solution, but it didn't work because of 'import library restrictions' agilent vee 9...
(6,027 Views)
Hey Michalmm,
 I think You should also give a try to the NI-DAQmx .dll. For the C API it is "nicaiu.dll" .  A discussison of the C API installs with the driver at Start>>Programs>>National Instruments>>NI-DAQ>>NI-DAQmx C Reference Help.
As for instructions on how to call the ANSI C functions within VEE, You should give a call to Agilent for their advice. Keep in mind that Agilent VEE is not supported natively, but hopefully You'll have a working application this way.
David Varga
NIH
(6,024 Views)
